# Page Not Found
The URL `code-in-n8n/use-built-in-shortcuts/langchain-code-node.md]` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [LangChain Code node](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/langchain-code-node.md)
- [HTTP node](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/http-node.md)
- [n8n metadata](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/n8n-metadata.md)
- [Use built-in shortcuts](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts.md)
- [JMESPath](https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/jmespath.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.n8n.io/build/code-in-n8n/use-built-in-shortcuts/langchain-code-node.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/build/code-in-n8n/use-built-in-shortcuts/langchain-code-node.md`).
